G4WIM PA controller
Configurations
The resulting system can be configured in three ways:
- Full remote control of the PA and shack monitoring of vital signs – using radio link.
- When PA is in the shack, local control and monitoring - no radio link.
- Remote control of PA by means of DC down the coax – no radio link or remote monitoring
Monitoring
- Vdd, 100mV resolution
- Idd, 100mA resolution
- PA temperature, 0.3C resolution
- Bias voltage, 10mV resolution for LDMOS
- RF power (forward or reverse but not both – depends on HW implementation)
- Fan status on or off
- Standby status on or off
Amplifier choices
The design was initially conceived for a Pyro Jo PA which needs 24V DC bias to activate it, subsequently it was modified to provide a temperature compensated bias for LDMOS FET’s. Basically for the LDMOS FET use the temp compensated bias circuit and for the Pyro JO PA use the 24V DC device – one or the other NOT both.
See CQ-TV article and schematics for more detail.
Documentation
Bill of material
File:G4WIM PA CONTROLLER V2-0 BOM.xlsx
Schematics
Source code
File:Atmel_BATC_Unified_PA_Controller.zip
The radio link uses an nRF905 and Atmel nano – this solution is a copy of this design http://blog.zakkemble.net/nrf905-avrarduino-librarydriver/comment-page-1/ but with minor code changes. It is very easy to build / modify using the Arduino environment but you will need to down load the library from the above site. The nRF905_config.h file allows setting of the frequency and power. The only other minor code changes required within the ino file is to remove the “TO” time out message being sent and to set the baud rate to 2400.
Comment out line 110 as per below:
if(timeout) // Timed out{Serial.println(F("TO"));break;}
Wireless Serial Link Arduino code is found here: https://github.com/zkemble/nRF905/tree/master/arduino/nRF905/examples/wirelessSerialLink
