MiniTioune
Revision as of 07:08, 28 July 2016 by G8GTZ (talk | contribs) (Created page with "MiniTiouner is a USB connected hardware project for receiving digital TV transmissions on the amateur radio or broadcast bands. When used with the Tutuione DVB-S receive and a...")
MiniTiouner is a USB connected hardware project for receiving digital TV transmissions on the amateur radio or broadcast bands. When used with the Tutuione DVB-S receive and analysis software from F6DZP it can be used to receive DVB-S QPSK transmission from broadcast and amateur TV transmissions with symbol rates (SR) from 30 Msymbols down to 112Ksymbols per second.
This very wide symbol rate range means it is capable of receiving all amateur TV transmission, including the Reduced Bandwidth (RB-TV) transmission below 1 Msymbol, and can also be used to receive domestic sateliite transmissions. The unit currently receives DVB-S QPSK transmissions only, but may receive other modes in the future with further PC software development.
When used with the Sharp or Samsung tuner or NIM component, frequency coverage is from 650 MHz through to 2600 MHz. This extended frequency coverage gives greater flexibility when working with upconverters from the VHF bands and enables the 10 GHz band, including eshailsat down link, to be received on a standard domestic PLL LNB.
The hardware consists of 3 major components – the Tuner or NIM, the USB interface and power supply components.
The extended range Sharp tuner and pre-programmed USB interface module and a blank PCB are available from the BATC on line shop https://batc.org.uk/shop/hardware-and-kits – all other components are available from normal suppliers.
Documentation
