Ryde Requirement Specification
Revision as of 20:15, 29 August 2020 by G8GKQ (talk | contribs) (Created page with "==Original requirement specification - April 2020== With the lack of any reliable source for STB hardware (a recent ebay purchase of quantity 3 of one item delivered 3 major...")
Outline specification
Code base
Functionality
Network capability
