Configuring your channel
To configure your streaming channel you will need to log in as a member and then go to your account dashboard - see this page for more details on your account dashboard - scroll down on the page to Streaming details.
Chat nick name
Stream Title
Stream output URL
Note - the full URL is made up of the https address above the grey box PLUS the text in the grey box (which is the stream name) without any spaces between them.
Stream input URL
Note - the full URL is "rtmp://rtmp.batc.org.uk/live/callsign-keykey" where callsign is the stream name listed in the first grey box and keykey is the key listed in the second grey box. The stream name and key are separated by a hyphen.
Streaming from the Portsdown
The Portsdown is already set up to stream to the streamer. From the Touchscreen:
  1. Select Menu 3
  2. Select "Set Stream Outputs"
  3. Select "Amend Preset"
  4. Choose which of the 8 buttons to program and select it
  5. Change the keyboard to lower case and enter the stream name and press enter
  6. Change the keyboard to lower case and enter the stream key and press enter
  7. Exit to Main Menu
  8. Select "Output to"
  9. Select BATC Stream
  10. Select the Video source
  11. Press TX
Using Adobe Media encoder
  • In the FMS URL: box put "rtmp://rtmp.batc.org.uk/live" (Note there is no / on the end)
  • In the Stream: box put your "callsign-key".
Using Vmix
For Vmix, put rtmp://rtmp.batc.org.uk/live in the "URL" field and the stream name and key separated by a hyphen (for example g8gkq-abcxyz) in the "Stream Name or Key" field.
Using OBS
For OBS, put rtmp://rtmp.batc.org.uk/live in the "URL" field and the stream name and key separated by a hyphen (for example g8gkq-abcxyz) in the "Stream key" field.
Using an H265 Encoder Box
The Chinese H265 / 264 encoder box (model ON-DMI-16D) can also stream using RTMP to the BATC streamer site while at the same time 'multi-casting' to your Pluto for RF transmission and streaming rtsp for local monitoring on VLC. However currently the BATC streamer will only accept H264 which means that your Pluto will also have to be set to H264 on the Pluto controller page. The endocer cannot produce H264 for the BATC streamer and H265 for Pluto at the same time.
The url for the RTMP stream to the BATC streamer is of the form:
rtmp://88.80.184.32/live/your_callsign-keykey
One thing to be aware of is when entering the 6 character key make sure you get it correct - my key happened to contain character "I" capital i, which can be confused with lowercase L . Using capital i fixed the problem !
The error was caused by copying the key on paper from the RPI 7" LCD streamer where both characters look the same.
To see the output of the encoder box locally using VLC enter this url rtsp://192.168.1.120:554/live/0 into VLC. This assumes your encoder box IP address is 192.168.1.120
Stream type
This selection determines if your stream appears as a member, repeater or special event stream in the streamer main channel list (https://batc.org.uk/live/). You cannot change this.
Stream options
Streaming type
The Streaming Type sets the default video player type on the Live Stream page, this can be set to either Flash or HTML5.
Flash Player
Advantages
  • Minimal delay (typically less than 1 second)
Disadvantages
  • The user needs Flash Player plugin installed, and manually enabled.
    • If the webpage detects that Flash is not installed, the user will then be given a link to use HTML5 player to view the stream.
HTML5 Player
Advantages
  • Plays without plugins on all modern desktop and mobile (phone/tablet) browsers
Disadvantages
  • Long and variable delay (typically 10-20 seconds depending on user's browser)
Stream description
The stream description is the area below the video player and text chat windows on your channel page. You can use this area to describe your channel and give more details of your group or repeater.
It is a free text area and can include HTML - we recommend you use an external HTML editor such as https://html-online.com/editor/ to get the correct look and then paste the code into the space.
Please note any embedded content such as maps and time clocks etc from other sites must use an SSL connection and have an https:// address.
