Winter Hill receiver project
Revision as of 13:27, 2 March 2021 by G0MJW (talk | contribs)
Winter Hill
The Winter Hill receiver project by Brian G4EWJ with hindrance occasional help from Mike G0MJW. It uses the BATC Advanced receiver hardware.
The software will run on the Raspberry Pi4 desktop environment providing a multi-channel receiver capable of receiving up to four channels simultaneously.
Timeline
Version 0.1
Version 0.2
A prototype that was also built by several beta testers.
Version 1
TBD
Hardware Build
Schematic is here:
BOM is here:
It is best to build this in order of component height. It took the author about 3 hours. There is an old proverb, a man with a watch knows the time. A man with two watches is never sure. While working with SMT, if you make a mistake, having two soldering irons to had is a great help when removing misplaced components. The other essential trick is to have the right tools for the job, a fine tip iron and thin, ideally 0.3mm solder. With experience you can use bar solder and a poker, but you are on your own there. Plenty of light and magnification is a must. If you don't have a magnifier then some +2 or +3 reading glasses might help those with normal vision.
Starting with an unpopulated PCB fit all the parts shown:
Low profile parts
Next fit the PICs - ideally use IC sockets
Higher
