Winter Hill receiver project
Winter Hill
The Winter Hill receiver project by Brian G4EWJ with hindrance occasional help from Mike G0MJW. It uses the BATC Advanced receiver hardware.
The software will run on the Raspberry Pi4 desktop environment providing a multi-channel receiver capable of receiving up to four channels simultaneously.
Timeline
Version 0.1
Version 0.2
A prototype that was also built by several beta testers.
Version 1
TBD
Hardware Build
Schematic is here:
It is best to build this in order of component height. It took the author about 3 hours. There is an old proverb, a man with a watch knows the time. A man with two watches is never sure. While working with SMT, if you make a mistake, having two soldering irons to had is a great help when removing misplaced components. The other essential trick is to have the right tools for the job, a fine tip iron and thin, ideally 0.3mm solder. With experience you can use bar solder and a poker, but you are on your own there. Plenty of light and magnification is a must. If you don't have a magnifier then some +2 or +3 reading glasses might help those with normal vision.
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Now for the PI GPIO header. This requires thought and care. It needs to be at the correct height above the PCB and that depends on how you plan to mount the PI and if it has a heatsink case or not. Test fit the header to the PI and mount the PI on the PCB, then the header will be in the correct place. Removing the header afterwards is almost impossible without damaging the PCB so take time to get this right. Best now remove the PI to prevent damage, or treat it with care if you choose not to. If it is in the metal case it will probably be fine.
Fit the fan if required.
Step 8
Step 9
Testing
If all OK, go to the software installation section. The PI OS needs to be loaded and the PICs need to be programmed.
