Advanced receiver hardware
The BATC advanced receiver hardware is a PCB designed to host up to 2 Serit FTS4334L or FTS4335 NIMs, which can receive DVB-S or DVB-S2, and a Raspberry Pi4.
Boxed
Applications
The first application to use the advanced receiver hardware will be the Winter Hill receiver project which is a multi-channel DVB-S2 receiver running on a RPi desktop.
Hardware Build
Finished PCB: Built Hardware
Schematic is here: File:Winterhill.pdf
It is best to build this in order of component height. It took the author about 3 hours. There is an old proverb, a man with a watch knows the time. A man with two watches is never sure. While working with SMT, if you make a mistake, having two soldering irons to had is a great help when removing misplaced components. The other essential trick is to have the right tools for the job, a fine tip iron and thin, ideally 0.3mm solder. With experience you can use bar solder and a poker, but you are on your own there. Plenty of light and magnification is a must. If you don't have a magnifier then some +2 or +3 reading glasses might help those with normal vision.
Step 1
Low profile parts
Step 2
Higher
Step 3
Caps that are not bipolar
Step 4
Pin Headers
Step 5
More Headers
Step 6
Regulators and Chokes
Step 7
Now for the PI GPIO header. This requires thought and care. It needs to be at the correct height above the PCB and that depends on how you plan to mount the PI and if it has a heatsink case or not. Test fit the header to the PI and mount the PI on the PCB, then the header will be in the correct place. Removing the header afterwards is almost impossible without damaging the PCB so take time to get this right. Best now remove the PI to prevent damage, or treat it with care if you choose not to. If it is in the metal case it will probably be fine.
GPIO Header3D view
Fit the fan if required.
GPIO Header
Step 8
Step 9
Completed boardNIMs
Testing
If all OK, go to the software installation section. The PI OS needs to be loaded and the PICs need to be programmed.
