Winter Hill receiver project
Winter Hill
The Winter Hill receiver project by Brian G4EWJ with hindrance and occasional help from Mike G0MJW. It uses the BATC Advanced receiver hardware.
The software will run on the Raspberry Pi4 desktop environment providing a multi-channel receiver capable of receiving up to four channels simultaneously.
Features
• WinterHill is a 4 channel DVB-S/S2 receiver based on the BATC Advanced Receiver pcb
• The main components are a Raspberry Pi 4 (RPi4), 2 PICs and 2 FTS433x NIMs
• The PICs are programmed in-circuit
• New RPi4 software, PIC software and PC software designed by G4EWJ
• PCB designed by G0MJW
• Installation software designed by G8GKQ
• The 4 received transport streams (TS) can be sent to any location using UDP protocol
• Transport streams are displayed either locally or remotely using VLC
• Receive commands can come from various sources, including QO-100 LiveTune designed by M0DTS
• Currently, the lowest symbol rate that can be received is 66kS.
• WinterHill is named in memory of Brian G3SMU, who was a huge presence on ATV and microwaves from his Winter Hill QTH in Lancashire, North-West England.
Timeline
Version 0.1
Version 0.2
Version 1
Documentation
Raspberry Pi4 SD Card Building and Software Installation Manual (contains software download details)
Operation Manual
PC Control and Viewing Utilities Manual
PC Control and Viewing Software
