Winter Hill receiver project
Winter Hill
The Winter Hill receiver project by Brian G4EWJ with hindrance and occasional help from Mike G0MJW. It uses the BATC Advanced receiver hardware.
The software will run on the Raspberry Pi4 desktop environment providing a multi-channel receiver capable of receiving up to four channels simultaneously.
Features
• The main components are a Raspberry Pi 4 (RPi4), 2 FTS433x NIMs, 2 PICs and 2 optional LNB PSU boards
• The PICs are programmed in-circuit
• The 4 received transport streams (TS) can be sent to any location using UDP protocol
• Transport streams are displayed either locally or remotely using VLC
• Receive commands can come from various sources, including QO-100 LiveTune designed by M0DTS
• The highest symbol rate is limited by the speed of the serial connections between devices and is about 10M bit/s per NIM. E.g. the QO- 100 beacon at SR1500 FEC4/5 (2.4Mbps) and a terrestrial repeater at SR4000 FEC7/8 (7Mbps) should be OK.
• Currently, the lowest symbol rate that can be received is 66kS.
Timeline
Version 0.1
Version 0.2
Version 1
Documentation
Raspberry Pi4 SD Card Building and Software Installation Manual (contains software download details)
Operation Manual
PC Control and Viewing Utilities Manual
PC Control and Viewing Software
