Winter Hill receiver project
WinterHill
The software will run on the Raspberry Pi4 desktop environment providing a multi-channel receiver capable of receiving up to four channels simultaneously.
Features
• The 4 received transport streams (TS) can be sent to any location using UDP protocol
• Transport streams are displayed either locally or remotely using VLC
• Receive commands can come from various sources, including QO-100 LiveTune designed by M0DTS
Timeline
Version 0.1
Version 0.2
Version 1
Documentation
Raspberry Pi4 SD Card Building and Software Installation Manual (contains software download details)
Operation Manual
PC Control and Viewing Utilities Manual
PC Control and Viewing Software
