Winter Hill receiver project
WinterHill
Features
• The 4 received transport streams (TS) can be sent to any location using UDP protocol
• Transport streams are displayed either locally or remotely using VLC
Timeline
Version 0.1
Version 0.2
Version 1
Documentation
Raspberry Pi4 SD Card Building and Software Installation Manual (contains RPi software download details)
Operation Manual
PC Control and Viewing Utilities Manual
PC Control and Viewing Software
