Winter Hill receiver project
Revision as of 15:29, 14 March 2021 by G4EWJ (talk | contribs)
WinterHill
Features
• The 4 received transport streams (TS) can be sent to any location using UDP protocol
Timeline
Version 0.1
Version 0.2
Version 1
Documentation
Raspberry Pi4 SD Card Building and Software Installation Manual (contains RPi4 software download details)
Operation Manual
PC Control and Viewing Utilities Manual
PC Control and Viewing Software
