WinterHill Receiver Project
Revision as of 12:59, 17 March 2021 by G8GKQ (talk | contribs) (Created page with "==WinterHill== The WinterHill receiver project by Brian G4EWJ with hindrance and occasional help from Mike G0MJW. It uses the BATC '''Advanced receiver hardware'''. Fi...")
WinterHill
Features
Timeline
Version 0.1
Version 0.2
Version 1
Documentation (coming soon)
Raspberry Pi4 SD Card Building and Software Installation Manual (contains RPi4 software download details)
Operation Manual
PC Control and Viewing Utilities Manual
Software (coming soon)
PC Control and Viewing Software
