WinterHill Receiver Project
WinterHill
Features
Timeline
Version 0.1
Version 0.2
Version 1
Documentation (coming soon)
Raspberry Pi4 SD Card Building and Software Installation Manual (contains RPi4 software download details)
Operation Manual
PC Control and Viewing Utilities Manual
Software (coming soon)
Control and Viewing Software for the PC
WinterHill Receive Commander - send receive commands from a PC to WinterHill File:whpcrxcom-3v20d.zip
