WinterHill Receiver Project
WinterHill
Features
Timeline
Version 0.1
Version 0.2
Version 1
Documentation (coming soon)
Raspberry Pi4 SD Card Building and Software Installation Manual (contains RPi4 software download details)
Operation Manual
PC Control and Viewing Utilities Manual
Software (coming soon)
Control and Viewing Software for the PC
WinterHill Receive Commander - sends receive commands from a PC to WinterHill File:whpcrxcom-3v20d.zip
WinterHill VLC Multi Viewer - displays the 4 channels received by WinterHill File:whpcviewer-3v20d.zip
