WinterHill Receiver Project
WinterHill
Features
Timeline
Version 0.1
Version 0.2
Version 1
Documentation (coming soon)
Raspberry Pi4 SD Card Building and Software Installation Manual (contains RPi4 software download details):
Operations Manual - covers the Raspberry Pi and PC Control and Viewing utilities:
Software (coming soon)
Control and Viewing Software for the PC - see the included README files for installation instructions:
WinterHill Receive Commander - sends receive commands from a PC to WinterHill File:whpcrxcom-3v20d.zip
WinterHill VLC Multi Viewer - displays the 4 channels received by WinterHill File:whpcviewer-3v20d.zip
