WinterHill Receiver Project
Revision as of 22:59, 23 March 2021 by G4EWJ (talk | contribs) (→Software)
WinterHill
Features
Timeline
Version 0.1
Version 0.2
Version 1
Documentation
Raspberry Pi4 SD Card Building and Software Installation Manual (contains RPi4 software download details):
Operations Manual - covers the Raspberry Pi and PC Control and Viewing utilities:
Control and Viewing Software for the PC. See the included README files for installation instructions. See the WinterHill Operations manual for usage instructions.
WinterHill Receive Commander - sends receive commands from a PC to WinterHill: File:whpcrxcom-3v20d.zip
WinterHill Multi VLC Viewer - displays the 4 channels received by WinterHill: File:whpcviewer-3v20d.zip
