WinterHill Receiver Project
WinterHill
Features
Timeline
Version 0.1
Version 0.2
Version 1
Documentation
Raspberry Pi Software
The software build process for WinterHill is different from Portsdown or Ryde. The process is full documented in the Installation Manual above, but the basic flow is:
- Write Raspios Buster Desktop image to SD Card and add ssh file
- Boot Raspberry Pi with display, keyboard and mouse and configure and update desktop (see manual)
- Download software from BATC WinterHill GitHub
- Install software and reboot
PC Software
Receive Commander - sends receive commands from a PC to WinterHill: File:whpcrxcom-3v20d.zip
Multi VLC Viewer - displays the 4 channels received by WinterHill:
