WinterHill Receiver Project
Revision as of 23:18, 23 March 2021 by G8GKQ (talk | contribs) (→PC Software)
WinterHill
Features
Timeline
Version 0.1
Version 0.2
Version 1
Documentation
Raspberry Pi Software
The software build process for WinterHill is different from Portsdown or Ryde. The process is full documented in the Installation Manual above, but the basic flow is:
  • Install software and reboot
PC Software
Receive Commander - sends receive commands from a PC to WinterHill: File:whpcrxcom-3v20d.zip
PC Software
WinterHill is also compatioble with M0DTS's QuickTune software: M0DTS Quick Tune GitHub Page
