WinterHill Receiver Project
Revision as of 23:22, 23 March 2021 by G8GKQ (talk | contribs) (→PC Software)
WinterHill
Features
Timeline
Version 0.1
Version 0.2
Version 1
Documentation
Raspberry Pi Software
  • Install software and reboot
PC Software
Receive Commander - sends receive commands from a PC to WinterHill: File:whpcrxcom-3v20d.zip
Multi VLC Viewer - displays the 4 channels received by WinterHill: To be published soon
WinterHill is also compatioble with M0DTS's QuickTune software: M0DTS Quick Tune GitHub Page
