WinterHill Receiver Project
WinterHill
Features
Timeline
Version 0.1
Version 0.2
Version 1
Documentation
Raspberry Pi Software
  • Install software and reboot
PC Software
Receive CommandFile:whpcviewer-3v20d.ziper - sends receive commands from a PC to WinterHill: File:whpcrxcom-3v20d.zip
Multi VLC Viewer - displays the 4 channels received by WinterHill: File:whpcviewer-3v20d.zipn
WinterHill is also compatible with M0DTS's QuickTune software: M0DTS Quick Tune GitHub Page
