WinterHill Receiver Project
Revision as of 23:29, 23 March 2021 by G4EWJ (talk | contribs) (→PC Software)
WinterHill
Features
Timeline
Version 0.1
Version 0.2
Version 1
Documentation
Raspberry Pi Software
  • Install software and reboot
PC Software
Receive CommandFile:whpcviewer-3v20d.ziper - sends receive commands from a PC to WinterHill: File:whpcrxcom-3v20d.zip
WinterHill is also compatible with M0DTS's QuickTune software: [1]
