WinterHill Receiver Project
Revision as of 10:54, 3 April 2021 by G4EWJ (talk | contribs)
WinterHill
Features
Timeline
Version 0.1
Version 0.2
Version 1
Documentation
Raspberry Pi Software
  • Install software and reboot
PC Software
Problems
Some strange behaviour has been seen when using a TV as an HDMI monitor for the Raspberry Pi
