WinterHill Receiver Project
WinterHill
Features
Timeline
Version 0.1
Version 0.2
Version 1
Documentation
Raspberry Pi Software
- Write Raspios Buster Desktop image to SD Card and add ssh file
- Boot Raspberry Pi with display, keyboard and mouse and configure and update desktop (see manual)
- Download software from BATC WinterHill GitHub
- Install software and reboot
PC Software
Problems
