WinterHill Receiver Project
Revision as of 10:32, 19 April 2021 by G4EWJ (talk | contribs) (→‎Problems)
WinterHill
Features
Timeline
Version 0.1
Version 0.2
Version 1
Documentation
Raspberry Pi Software
  • Install software and reboot
PC Software
Problems
HDTV Monitors
VLC (on PC) Initial Screen
