23cms filters
Good 23cms filters are easy to build and there are plenty of designs available on the web:
Simple band pass filter for 23cms
A nice simple to construct design by GM8OTI http://www.marwynandjohn.org.uk/GM8OTI/proj23cmBPF/proj23cmBPF.html
Example made by M0YDH (using capacitors found in the Finningley ARS scrap heap during CAT17!). Thanks to John Cooke GM8OTI for the drawing where dimensions in blue are the result of scaling. Elements are brass rods Ø3mm x 19 long off inside face. Design is dependant on high quality capacitors. W6PQL filters may have lower insertion loss.
Look through cavity filter for 23cms
Design published in CQ-TV 245
3 and 5 pole filters
Easy to make in a standard diecast box
http://www.w6pql.com/23cm_filters.htm
Pictures of the 5 pole version made by David M0YDH. Cables and coupler only measured at -9.75dBm indicating an inserion loss of 2.3dBm for the filter. Wire loops are 12mm long. Blutak and a 1mm thick washer were very helpful during assembly soldering for positioning the loops. Poles are 50mm long and M4 screws were used. It is important to produce a good D hole for the connectors - in this case filing out a Ø5mm hole to get a snug, anti-rotation hole for the SMA connectors. Filter centre was adjusted from 1296 to 1249 - 1255 MHz. The long brass screws affect the insertion loss by tenths of a dB - very fine tuning!
Low Pass Filter
Kuhne PCB 58 is a low pass filter and coupler rated up to 30W. This is available as a kit of PCB, tinplate box and SMA connectors from Alan Melia G3NYK. 3/4 of the way down the page. It's priced £21.50 in 2018. This does not include discrete components for the coupler portion.
The PCB is originally shown here
Under downloads there is a Beschreibung / Descriptions link which contains a PDF with full spec, schematic and colour photos.
Neil G4DBN has published test results for the filter and populated the coupler circuit. NB the diode he chose is stripe marked at the ANODE end - when you use very high magnification!
Manufacturers
- Antennair - suppliers of the DTX1
- DG0VE - German supplier of reasonably priced filters for most amateur bands now sadly SK - company closed 2019
- Aerial-parts-uk - 23cm Interdigital, Filter Response measured at the 2016 Martlesham Microwave Round table as follows:-
