MiniTioune
Revision as of 15:09, 22 December 2016 by W6HHC (talk | contribs)
MiniTioune is a USB connected hardware project for receiving digital TV transmissions on the amateur radio or broadcast bands. When used with the Tutuione DVB-S receive and analysis software from F6DZP it can be used to receive DVB-S QPSK transmission from broadcast and amateur TV transmissions with symbol rates (SR) from 30 Msymbols down to 112Ksymbols per second.
The very wide symbol rate range means it is capable of receiving all amateur TV transmissions, including the Reduced Bandwidth (RB-TV) transmission below 1 Msymbol and the HamTV signals from the ISS. Whilst the hardware is capable of receiving DVB-S2, the Minitioune system currently only receives DVB-S QPSK transmissions, but may receive other modes in the future with further PC software development.
The hardware consists of 3 major components – the Tuner or NIM, the USB interface and power supply components.
The extended range Sharp tuner and pre-programmed USB interface module and a blank PCB are available from the BATC on line shop https://batc.org.uk/shop/hardware-and-kits – all other components are available from normal suppliers.
Hardware Documentation
Software Downloads
Software is hosted on the VivaDATV forum. You need a log-in to download, but here are the links:
The latest (4 September 2016) version of MiniTioune V0.4c: http://www.vivadatv.org/viewtopic.php?f=60&t=361
Software Installation
The following areas are involved with the installation of drivers and Software for MiniTioune on Windows10 OS:
  • Run the MiniTiouner_v0.4c executable & perhaps adjust the decoder filters being used.
W6HHC - http://w6ze.org/DATV/InstallingMiniTiouner_onWin10.pdf
