Portsdown 4 Langstone Integration
Revision as of 08:57, 12 July 2021 by G8GKQ (talk | contribs)
Background
The Portsdown 4 is designed to work alongsde the Langstone Microwave Transceiver, using common hardware. However, the 2 projects are separate with differing priorites.
Before trying to install the Langstone on your Portsdown hardware, check that you have:
  • A Pluto SDR connected by USB (at least initially)
  • The correct USB audio dongle. Non-supported USB dongles will not work.
  • A USB mouse for use as a scrollwheel
Initial Installation
From Menu 3, select Langstone Config, Install Langstone.
If your Plu
