Portsdown NF Meter
General Principle
Equipment Required
To measure noise figure using a Portsdown 4, a calibrated noise source and matching switched power supply are required.
Many professional noise sources (as used by HP) need a 28v supply in their on state. They have a stated "Excess Noise Ratio" (ENR) which is a measure of the noise that they produce, and they may well have a calibration chart or table stating how this ENR varies with frequency. Typical ENR values are 5 or 15 dB.
The switched power supply needs to turn the noise source on when commanded to by the Portsdown 4 and then turn it off again. The drive for the noise source switching comes from pin 26 of the Portsdown GPIO port, and is at 3.3v when the noise source is on, and 0v when the noise source is off. It is hoped to publish some circuits for possible switched power supplies in future, but there is an example here: https://www.qsl.net/yo4hfu/Files/CANFI/SWITCH_28V.pdf .
