Portsdown NF Meter
General Principle
Equipment Required
To measure noise figure using a Portsdown 4, a Lime SDR Mini, calibrated noise source and matching switched power supply are required.
Many professional noise sources (as used by HP) need a 28v supply in their on state. They have a stated "Excess Noise Ratio" (ENR) which is a measure of the noise that they produce, and they may well have a calibration chart or table stating how this ENR varies with frequency. Typical ENR values are 5 or 15 dB.
If you do not have a calibrated HP or similar noise source, G8FEK of RF Design sells some suitable models: https://g8fek.com/precision-noise-sources.html . Note that these need a 30v, not 28v, supply.
The switched power supply needs to turn the noise source on when commanded to by the Portsdown 4 and then turn it off again. The drive for the noise source switching comes from pin 26 of the Portsdown GPIO port, and is at 3.3v when the noise source is on, and 0v when the noise source is off. It is hoped to publish some circuits for possible switched power supplies in future, but there is an example here: https://www.qsl.net/yo4hfu/Files/CANFI/SWITCH_28V.pdf .
Making a Measurement
Connect your switched power supply to the Portsdown 4. Apply the switched power supply to the Noise Source and initially (assuming a 15 dB or 5 dB ENR noise source) connect the noise source directly to the LimeSDR Mini receive port. The LimeSDR should of course be connected to the Portsdown by USB.
The LimeSDR should have gateware V1.30 or the LimeDVB gateware loaded.
From Menu 2, select Test Equipment, NF Meter. You should see the screen below.
