Portsdown NF Meter
General Principle
Equipment Required
To measure noise figure using a Portsdown 4, a Lime SDR Mini, calibrated noise source and matching switched power supply are required.
Many professional noise sources (as used by HP) need a 28v supply in their on state. They have a stated "Excess Noise Ratio" (ENR) which is a measure of the noise that they produce, and they may well have a calibration chart or table stating how this ENR varies with frequency. Typical ENR values are 5 or 15 dB.
If you do not have a calibrated HP or similar noise source, G8FEK of RF Design sells some suitable models: https://g8fek.com/precision-noise-sources.html . Note that these need a 30v, not 28v, supply.
The switched power supply needs to turn the noise source on when commanded to by the Portsdown 4 and then turn it off again. The drive for the noise source switching comes from pin 26 of the Portsdown GPIO port, and is at 3.3v when the noise source is on, and 0v when the noise source is off. It is hoped to publish some circuits for possible switched power supplies in future, but there is an example here: https://www.qsl.net/yo4hfu/Files/CANFI/SWITCH_28V.pdf .
Preparing for a Measurement
Connect your switched power supply to the Portsdown 4. Apply the switched power supply to the Noise Source and initially (assuming a 15 dB or 5 dB ENR noise source) connect the noise source directly to the LimeSDR Mini receive port. The LimeSDR should of course be connected to the Portsdown by USB.
The LimeSDR should have gateware V1.30 or the LimeDVB gateware loaded.
From Menu 2, select Test Equipment, NF Meter. After the levels have setted (which may take 10 seconds or so) you should see the screen below.
The first setting to make is the frequency. Press "Return to Main menu", "Freq and Bandwidth" and then "Centre Freq". Set your desired measurment frequency. Alternatively, you can use one of the presets (146.5, 437, 748, 1255 or 2409). Then select "Set-up Menu" again. The entered frequency should be the signal frequency if you are testing a preamp, BUT should be the IF frequency if you are testing a transverter. It is suggested that the measurement bandwidth is left at 2 MHz (as was standard on the early HP Noise Figure meters) but it can be adjusted down to 500 kHz and up to 20 MHz at this point.
Next you need to enter the ENR of your noise source. Touch the ENR button and enter the exact ENR for your noise source at the selected frequency (read from its calibration chart). Note that if you are testing a transverter (and obviously a preamp) this should be for the signal frequency, not the IF frequency.
Making a Simple Measurement
If you now insert your preamp or transverter (the Device Under Test) between the noise source and the LimeSDR, you should see the "System" NF improve (hopefully) and you can make adjustments to your device to optimise its performance. What is displayed on the NF Meter is the noise figure of the system comprising your device and the LimeSDR. This means that if your device has low gain, the LimeSDR might introduce a contribution to the total measured noise figure. However, this mode enables quick and easy optimisation, and is very useful for general bench testing.
To perform the calibration, connect the noise head directly to the LimeSDR, and set the frequency, bandwidth and gain as specified above. Then, in the Set-up Menu, press "Calibrate". The system will average a number of readings and then display the "Device" noise figure and gain, which should be around zero. Now put your preamp in circuit, and the meter will display the preamp (the "Device") noise figure and gain as shown below.
Note that although this method can be made to work for transverters to give an indication of NF and gain, the values will not be accurate, as the NF Meter calibration will have occured at the IF frequency, not the signal frequency.
Meter Scale
The "analog" meter has 5 scale settings: a wide 30 to 0 dB, narrower 30 to 20 dB, 20 to 10 dB and 10 to 0 dB, and a narrow 5 t0 0 dB. You can move between these scales by touching the right or left side of the meter face. Note that the meter reads lower noise figure (better) to the right, and higher noise figure to the left. This is the convention followed on older analog Noise Figure meters.
Sources of Error
SDR non-linearity
Temperature effects
