Knucker
The Knucker project is to develop a reduced-bandwidth DVB-T USB receiver and transmitter for use on the lower VHF bands and HF. It will also have applications for mobile stations on 437MHz and above. The Knucker is not intended to be capable of receiving commercial broadcast TV transmissions.
Why DVB-T
DX!!
Why Knucker
Why not?
Timescales
The PCBs and Tuners went on general relase in March 2021. The receive software is included in the Portsdon 4 build from that date.
Interim receive software has also been included in the Ryde build (accessed through the SSH Console Menu).
Receiver
The Knucker may be used as a DVB-T receiver in conjunction with the Portsdown 4 or Ryde receiver. In Ryde, the DVB-T option is selected by either selecting a DVB-T Band or Preset using the remote control. It cal also be accessed from the ssh console menu.
Draft specifications are 150 kHz to 2 MHz wide OFDM, frequency range 44 to 1002MHz. The receiver software is included in the Portsdown 4 (touchscreen) and the Ryde.
Note that the DVB-T input to the NIM is the bottom F type nearest the PCB.
Version 1
Version 2
This was the first prototype build and not on general release. The old BOM and schematics are available here, but do not use them unless you are sure that you have an old board, and not the one that has been on sale since January 2021: File:Knucker.xlsx
Version 3
First general release PCB - released March 2021
USB Module
The USB module will require reprogramming with the xml file in this zip using the FTDI program called FT Prog - the standard MiniTiouner USB module from the BATC will not work but can be re-programmed as follows:
Download and install the FTDI FTprog software from here:
Download, unzip and save this file File:combituner.zip It will save as Knucker DVBT.xml
Put the USB module in to the PCB, apply power to the Knucker board, and connect the USB port to the PC - you should here the Windows bing bong sound. Note that to program the module in a Knucker PCB, power must be applied to the PCB (unlike the MiniTiouner).
Run FTprog:
Go - File>open template and open the .xml file
Go - Devices>Scan and parse
Your screen should now look like this:
Right click on the "Device:0" line
Apply template - select the template you have opened.
Right click again - Program Device
Go - Devices>Scan and parse and it should show your device as programmed.
Charles G4GUO has developed a core Linux DVB-T receiver application using information provided under a non-disclosure-agreement from the manufacturerm, so only the compiled binary (for a Raspberry Pi) is available for download.
Portsdown
The receive software has been integrated into the Portsdown 4 system to give a narrow band DVB-T receive capability. https://forum.batc.org.uk/viewtopic.php?f=103&t=7158
Ryde set top box
An interim SSH Menu-driven version has also been integrated into the Ryde Build. No remote control functions are available in this build, although full integration with Ryde is on the to-do list.
Transmit
Portsdown system
Due to excellent cooperation between Charles and Dave, a Portsdown DVB-T transmitter using the Pluto SDR has been integrated into the Portsdown 4.
The first official release was made on 1st February 2021
https://forum.batc.org.uk/viewtopic.php?t=7158&p=26210#p26210
Both the Portsdown 2020 and the Portsdown 4 have an H264 DVB-T transmit capability when used with the LimeSDR Mini.
DATV Express
