Christmas 2021 BATC Repeater Activity Contest and Activity Challenge
Revision as of 22:37, 9 December 2021 by G3gja (talk | contribs)
The Christmas Repeater Contest 2021 will run from Friday 24th December 2020 through to Monday 3rd January 2022 inclusive. The aim is to increase ATV repeater use. On offer is a £100 prize for the repeater group with the most contacts recorded.
The on-line entry and ladder system as used for last year's Contest on the BATC website will be used. The Ladder has fields for you to enter the points claimed and the repeater's callsign.
As well as the Repeater Challenge, you are invited to enter any non-repeater contacts you make so that the Contest becomes an Activity Ladder Challenge too. There are no prizes for the winner of the Activity Ladder Challenge but the first and second places will receive a certificate and your name and callsign will appear in CQ-TV with attached bragging rights, kudos etc.! Many repeater groups have found that their income has been slashed by the pandemic precautions, so here’s a chance to help your local repeater group and stir up some activity.
The rules are available in PDF form here: File:Christmas 2021 BATC REPEATER CONTEST- ACTIVITY CHALLENGE RULES.pdf and are reproduced below. Note the rules in the pdf document are the master version. The wiki text below may have been changed for clarification. Please note that the rules have changed from last year; this year multi-band contacts with the same station at the same location on any one day are not permitted. However, if they are from different locations, i.e., at least one QTH locator square different the contact is valid.
Christmas 2021 BATC REPEATER ACTIVITY CONTEST and ACTIVITY CHALLENGE RULES
3. Dates and Times. The contest will run from 0000hrs GMT on 24th December 2021 to 2359hrs GMT on the 2nd January 2021.
6. Power. Output power must not exceed that set out in the terms of your licence. 7. Exchange. Both a CALL SIGN and a FOUR-FIGURE code number must be conveyed via video and received via the repeater by another station. Reception of the repeater can either be via the RF output or the repeater's streaming channel. The same exchange should be used for direct contacts for points to be valid in the Challenge.
Confirmation of reception is by transmitting back the sum of the code numbers (not the actual transmitted number) on the repeater or on the talk-back channel. Confirmation via the streaming chat channel or other none radio means is allowed as is confirmation by another voice repeater (analogue or digital).
8. Scoring. The following multipliers should be used: 71MHz & 146MHz @ 5 points per km 70cm @ 3 points per km 23cm @ 2 points per km Contacts on higher bands @ 5 points per km. For the Repeater Activity Contest, points can be claimed for one band per station per day. You may not claim points for multiple contacts with the same station on the same day on different bands. You can claim points for working the same contacts on each day of the contest. For the Challenge, on any day you may work the same station on different bands and claim points for each contact.
Contacts from multiple locations are permitted on the same day, band and with the same callsigns. For example you can work into the repeater from home and then you can go out portable to two locations and all of the points earned /p can be added to those claimed for working the same stations on the same bands later in the day from the home station. RF or Internet links between two repeaters do not count for additional points.
10. On-line logging. Use the Activity Ladder page on the BATC website here: https://batc.org.uk/ladder and fill in the boxes for each contact as appropriate.
11. Receive only section. Send an e-mail to the Contest Manager with log shee.t attached giving your Call sign / BRS No. and name and address, Band, Date/Time, Call sign of station seen, Repeater Callsign, Repeater Locator, Locator of other station, Code number received, km from your station to repeater, km from repeater to distant station and points claimed.
Clive Reynolds G3GJA / G8EQZ BATC Contest Manager 8th December 2021
