Repeater GPIO Connections
RPi 4 GPIO pin out
  • Note the RPi4 (only) can be powered with 5.2 v directly on Pins 2 and 4. Ground is Pins 6, 9, 14, 20, 25, 30, 34 and 39.
GPIO Connections for the ATV Repeater
Pin No BCM No Wiring Pi RPi Pri RPi Alt0 Primary Use Secondary Use Notes
1 - - 3.3v - - - Future Clock module?
2 - - 5v - - - -
3 2 8 GPIO 2 SDA1 - - Future Clock module?
4 - - 5v - - - -
5 3 9 GPIO 3 SCL1 - - Future Clock module?
6 - - 0v - - - -
7 4 7 GPIO 4 GPCLK0 - - Future Clock module?
8 14 15 GPIO 14 TXD0 - - Future RS-232?
9 - - 0v - - - Future Clock module?
10 15 16 GPIO 15 RXD0 - - Future RS-232?
11 17 0 GPIO 17 FL1 - IR Sensor Input? For initial config
12 18 1 GPIO 18 - IR Sender Output - To control HDMI Switch
13 27 2 GPIO 27 SD0_DAT3 IR Bank Select - For second HDMI switch
14 - - 0v - - - -
15 22 3 GPIO 22 SD0_CLK - - Spare GPIO
16 23 4 GPIO 23 SD0_CMD RX 5 Active - Active high input
17 - - 3.3v - - - -
18 24 5 GPIO 24 SD0_DAT0 RX 3 Active - Active high input
19 10 12 GPIO 10 SPI0_MOSI RX 6 Active - Active high input
20 - - 0v - - - -
21 9 13 GPIO 9 SPI0_MISO RX 7 Active - Active high input
22 25 6 GPIO 25 SD0_DAT1 RX 4 Acive - Active high input
23 11 14 GPIO 11 SPI0_SCLK Output 6 select Spare GPIO Active high output
24 8 10 GPIO 8 SPI0_CE0_N Output 7 select Spare GPIO Active high output
25 - - 0v - - - -
26 7 11 GPIO 7 SPI0_CE1_N Hardware Shutdown - Active low if enabled
27 0 30 ID_SD SDA0 Reserved - Not Available
28 1 31 ID_SC SCL0 Reserved - Not Available
29 5 21 GPIO 5 GPCLK0 Output 5 select Spare GPIO Active high output
30 - - 0v - - - -
31 6 22 GPIO 6 GPCLK2 Output 4 select Spare GPIO Active high output
32 12 26 GPIO 12 PWM0 RX 1 Active - Active high input
33 13 23 GPIO 13 PWM1 Output 3 select Spare GPIO Active high output
34 - - 0v - - - -
35 19 24 GPIO 19 SPI6_MESO RX 2 Active - Active high input
36 16 27 GPIO 16 FL0 Output 0 select Spare GPIO Active high output
37 26 25 GPIO 26 SD0_DAT2 Output 1 select Spare GPIO Active high output
38 20 28 GPIO 20 SPI6_MOSI Output 2 select Spare GPIO Active high output
39 - - 0v - - - -
40 21 29 GPIO 21 SPI6_SCLK PTT for TX - Active high
The clock module that may be used (not tested yet) on pins 1, 3, 5, 7 and 9 is this https://thepihut.com/blogs/raspberry-pi-tutorials/17209332-adding-a-real-time-clock-to-your-raspberry-pi. This would allow the repeater to keep track of time without an internet connection and reset correctly after power outages.
Functional List
Function Pin
Receiver 1 Active 32
Receiver 2 Active 35
Receiver 3 Active 18
Receiver 4 Active 22
Receiver 5 Active 16
Receiver 6 Active 19
Receiver 7 Active 21
Example Example
Example Example
Example Example
Example Example
Example Example
Example Example
Example Example
Example Example
Example Example
Example Example
Example Example
Example Example
Example Example
Example Example
Example Example
Example Example
Example Example
