Repeater GPIO Connections
RPi 4 GPIO pin out
- Note the RPi4 (only) can be powered with 5.2 v directly on Pins 2 and 4. Ground is Pins 6, 9, 14, 20, 25, 30, 34 and 39.
GPIO Connections for the ATV Repeater
| Pin No | BCM No | Wiring Pi | RPi Pri | RPi Alt0 | Primary Use | Secondary Use | Notes |
| 1 | - | - | 3.3v | - | Clock module | - | - |
| 2 | - | - | 5v | - | - | - | - |
| 3 | 2 | 8 | GPIO 2 | SDA1 | Clock module | - | - |
| 4 | - | - | 5v | - | - | - | - |
| 5 | 3 | 9 | GPIO 3 | SCL1 | Clock module | - | - |
| 6 | - | - | 0v | - | - | - | - |
| 7 | 4 | 7 | GPIO 4 | GPCLK0 | Clock module | - | - |
| 8 | 14 | 15 | GPIO 14 | TXD0 | i2c sda | RS-232? | i2c needs 1k8 p/u to +5 |
| 9 | - | - | 0v | - | Clock module | - | - |
| 10 | 15 | 16 | GPIO 15 | RXD0 | i2c scl | RS-232? | i2c needs 1k8 p/u to +5 |
| 11 | 17 | 0 | GPIO 17 | FL1 | - | IR Sensor Input? | For initial config |
| 12 | 18 | 1 | GPIO 18 | - | IR Sender Output | - | To control HDMI Switch |
| 13 | 27 | 2 | GPIO 27 | SD0_DAT3 | IR Bank Select | - | For second HDMI switch |
| 14 | - | - | 0v | - | - | - | - |
| 15 | 22 | 3 | GPIO 22 | SD0_CLK | - | - | Spare GPIO |
| 16 | 23 | 4 | GPIO 23 | SD0_CMD | RX 5 Active | - | Active high input |
| 17 | - | - | 3.3v | - | - | - | - |
| 18 | 24 | 5 | GPIO 24 | SD0_DAT0 | RX 3 Active | - | Active high input |
| 19 | 10 | 12 | GPIO 10 | SPI0_MOSI | RX 6 Active | - | Active high input |
| 20 | - | - | 0v | - | - | - | - |
| 21 | 9 | 13 | GPIO 9 | SPI0_MISO | RX 7 Active | - | Active high input |
| 22 | 25 | 6 | GPIO 25 | SD0_DAT1 | RX 4 Acive | - | Active high input |
| 23 | 11 | 14 | GPIO 11 | SPI0_SCLK | Output 6 select | Spare GPIO | Active high output |
| 24 | 8 | 10 | GPIO 8 | SPI0_CE0_N | Output 7 select | Spare GPIO | Active high output |
| 25 | - | - | 0v | - | - | - | - |
| 26 | 7 | 11 | GPIO 7 | SPI0_CE1_N | Hardware Shutdown | - | Active low if enabled |
| 27 | 0 | 30 | ID_SD | SDA0 | Reserved | - | Not Available |
| 28 | 1 | 31 | ID_SC | SCL0 | Reserved | - | Not Available |
| 29 | 5 | 21 | GPIO 5 | GPCLK0 | Output 5 select | Spare GPIO | Active high output |
| 30 | - | - | 0v | - | - | - | - |
| 31 | 6 | 22 | GPIO 6 | GPCLK2 | Output 4 select | Spare GPIO | Active high output |
| 32 | 12 | 26 | GPIO 12 | PWM0 | RX 1 Active | - | Active high input |
| 33 | 13 | 23 | GPIO 13 | PWM1 | Output 3 select | Spare GPIO | Active high output |
| 34 | - | - | 0v | - | - | - | - |
| 35 | 19 | 24 | GPIO 19 | SPI6_MESO | RX 2 Active | - | Active high input |
| 36 | 16 | 27 | GPIO 16 | FL0 | Output 0 select | Spare GPIO | Active high output |
| 37 | 26 | 25 | GPIO 26 | SD0_DAT2 | Output 1 select | Spare GPIO | Active high output |
| 38 | 20 | 28 | GPIO 20 | SPI6_MOSI | Output 2 select | Spare GPIO | Active high output |
| 39 | - | - | 0v | - | - | - | - |
| 40 | 21 | 29 | GPIO 21 | SPI6_SCLK | PTT for TX | - | Active high |
The clock module that may be used (not tested yet) on pins 1, 3, 5, 7 and 9 is this https://thepihut.com/blogs/raspberry-pi-tutorials/17209332-adding-a-real-time-clock-to-your-raspberry-pi. This would allow the repeater to keep track of time without an internet connection and reset correctly after power outages.
Functional List
| Function | Pin |
| Receiver 1 Active | 32 |
| Receiver 2 Active | 35 |
| Receiver 3 Active | 18 |
| Receiver 4 Active | 22 |
| Receiver 5 Active | 16 |
| Receiver 6 Active | 19 |
| Receiver 7 Active | 21 |
| IR LED Drive | 12 |
| IR Bank Select | 13 |
| Transmitter PTT | 40 |
| Output 0 select | 36 |
| Output 1 select | 37 |
| Output 2 select | 38 |
| Output 3 select | 33 |
| Output 4 select | 31 |
| Output 5 select | 29 |
| Output 6 select | 23 |
| Output 7 select | 24 |
| Hardware Shutdown | 26 |
| IR Sensor | 11 |
