Repeater system basic IR configuration
The section of the config file for basic IR configuration is shown here for an HDMI switch with the following control codes:
Function | IR Code |
Input 1 | 0x17 |
Input 2 | 0x12 |
Input3 | 0x59 |
Input 4 | 0x08 |
Quad | 0x18 |
# Input config # Recommended gpio pins for "input active" are 32, 35, 18, 22, 16, 19 and 21
# announcemediatype determines the player used
# Switcher can use "ir" or "gpio" or "i2c" # IR uses a TX on GPIO pin 12 # GPIO uses pins 36, 37, 38, 33, 31, 29, 23, 24. Can be enabled with ir or i2c # i2c uses FMS6501A on Output channel 1 # activeinputhold (yes/no) means that lower priority inputs do not get replaced by higher priority (except pri 1) # Show Quad is yes/no and overides activeinputhold
# Number of available inputs does not include the controller, so is max 3 for a 4-input switch availableinputs=3 activeinputhold=no # Set next parameter to no if you do not want (or do not have) a quad display showquadformultipleinputs=yes cascadedswitches=no
outputswitchcontrol=ir showoutputongpio=yes outputhdmiresetcode=nec:0x17 output2ndhdmicode=nec:0x17 outputhdmiquadcode=nec:0x18 outputi2caddress=3 outputi2cquadchannel=9
input0name=Controller output0code=nec:0x17
- output0code=2nec:0x17 (daisy chain)
output0hdmiswitchpin=36 output0i2cchannel=1 output0audioi2cbit=0
input1name=Stream Input input1prioritylevel=1 input1activegpiopin=32 output1code=nec:0x12 output1hdmiswitchpin=37 output1i2cchannel=2 output1audioi2cbit=1 input1announcemediatype=jpg input1announcemediafile=/home/pi/tmp/input1.jpg input1announcemediaduration=3
input2name=QO-100 RX input2prioritylevel=2 input2activegpiopin=35 output2code=nec:0x59 output2hdmiswitchpin=38 output2i2cchannel=3 output2audioi2cbit=2 input2announcemediatype=jpg input2announcemediafile=/home/pi/tmp/input2.jpg input2announcemediaduration=3
input3name=3.4 GHz Ryde input3prioritylevel=3 input3activegpiopin=18 output3code=nec:0x08 output3hdmiswitchpin=33 output3i2cchannel=4 output3audioi2cbit=3 input3announcemediatype=jpg input3announcemediafile=/home/pi/tmp/input3.jpg input3announcemediaduration=3
