Repeater system full quad view IR configuration
Jump to navigation
Jump to search
The section of the config file for basic IR configuration is shown here for an HDMI switch with the following control codes:
Function | IR Code |
Input 1 | 0x17 |
Input 2 | 0x12 |
Input3 | 0x59 |
Input 4 | 0x08 |
Quad | 0x18 |
Substitute the codes for your HDMI switch if they are different. In the file that follows, note that IR codes of the form "2nec:0x17" first send the code for the upstream IR switch (in this case nec0x17), and then send the code to the downstream switch (in this case nec:0x12 which is set in the output2ndhdmicode=nec:0x12 parameter).
# Input config # Recommended gpio pins for "input active" are 32, 35, 18, 22, 16, 19 and 21 # announcemediatype determines the player used # Switcher can use "ir" or "gpio" or "i2c" # IR uses a TX on GPIO pin 12 # GPIO uses pins 36, 37, 38, 33, 31, 29, 23, 24. Can be enabled with ir or i2c # i2c uses FMS6501A on Output channel 1 # activeinputhold (yes/no) means that lower priority inputs do not get replaced by higher priority (except pri 1) # Show Quad is yes/no and overides activeinputhold
# Number of available inputs does not include the controller, so is max 6 availableinputs=6 activeinputhold=no showquadformultipleinputs=yes cascadedswitches=yes
outputswitchcontrol=ir showoutputongpio=yes outputhdmiresetcode=nec:0x17 output2ndhdmicode=nec:0x12 outputhdmiquadcode=2nec:0x18 outputi2caddress=3 outputi2cquadchannel=9 input0name=Controller output0code=nec:0x17 output0hdmiswitchpin=36 output0i2cchannel=1 output0audioi2cbit=0 input1name=70cms Ryde input1prioritylevel=1 input1activegpiopin=32 output1code=2nec:0x17 output1hdmiswitchpin=37 output1i2cchannel=2 output1audioi2cbit=1 input1announcemediatype=jpg input1announcemediafile=/home/pi/tmp/input1.jpg input1announcemediaduration=3 input2name=23cms Ryde input2prioritylevel=2 input2activegpiopin=35 output2code=2nec:0x12 output2hdmiswitchpin=38 output2i2cchannel=3 output2audioi2cbit=2 input2announcemediatype=jpg input2announcemediafile=/home/pi/tmp/input2.jpg input2announcemediaduration=3 input3name=Stream rxr input3prioritylevel=3 input3activegpiopin=18 output3code=2nec:0x59 output3hdmiswitchpin=33 output3i2cchannel=4 output3audioi2cbit=3 input3announcemediatype=jpg input3announcemediafile=/home/pi/tmp/input3.jpg input3announcemediaduration=3 input4name=Analogue Rxr input4prioritylevel=7 input4activegpiopin=22 output4code=2nec:0x08 output4hdmiswitchpin=31 output4i2cchannel=5 output4audioi2cbit=4 input4announcemediatype=jpg input4announcemediafile=/home/pi/tmp/input4.jpg input4announcemediaduration=3 input5name=Spare 1 input5prioritylevel=7 input5activegpiopin=16 output5code=nec:0x59 output5hdmiswitchpin=29 output5i2cchannel=6 output5audioi2cbit=5 input5announcemediatype=jpg input5announcemediafile=/home/pi/tmp/input5.jpg input5announcemediaduration=10 input6name=Spare 2 input6prioritylevel=8 input6activegpiopin=19 output6code=nec:0x08 output6hdmiswitchpin=23 output6i2cchannel=7 output6audioi2cbit=6 input6announcemediatype=jpg input6announcemediafile=/home/pi/tmp/input6.jpg input6announcemediaduration=3
If it is desired to have the quad available as a source in the carousel, then the availableinputs= could be increased from 6 to 7, and the following code added to make the quad a source that is then selectable in the carousel:
input7name=Quad input7prioritylevel=8 input7activegpiopin=21 output7code=2nec:0x18 output7hdmiswitchpin=24 output7i2cchannel=8 output7audioi2cbit=7 input7announcemediatype=jpg input7announcemediafile=/home/pi/tmp/input7.jpg input7announcemediaduration=3
