Repeater system full quad view IR configuration
The section of the config file for basic IR configuration is shown here for an HDMI switch with the following control codes:
| Function | IR Code |
| Input 1 | 0x17 |
| Input 2 | 0x12 |
| Input3 | 0x59 |
| Input 4 | 0x08 |
| Quad | 0x18 |
Substitute the codes for your HDMI switch if they are different. In the file that follows, note that IR codes of the form "2nec:0x17" first send the code for the upstream IR switch (in this case nec0x17), and then send the code to the downstream switch (in this case nec:0x12 which is set in the output2ndhdmicode=nec:0x12 parameter).
Fragment of Config file:
# Input config # Recommended gpio pins for "input active" are 32, 35, 18, 22, 16, 19 and 21 # announcemediatype determines the player used # Switcher can use "ir" or "gpio" or "i2c" # IR uses a TX on GPIO pin 12 # GPIO uses pins 36, 37, 38, 33, 31, 29, 23, 24. Can be enabled with ir or i2c # i2c uses FMS6501A on Output channel 1 # activeinputhold (yes/no) means that lower priority inputs do not get replaced by higher priority (except pri 1) # Show Quad is yes/no and overides activeinputhold # Number of available inputs does not include the controller, so is max 6 availableinputs=6 activeinputhold=no showquadformultipleinputs=yes cascadedswitches=yes
outputswitchcontrol=ir showoutputongpio=yes outputhdmiresetcode=nec:0x17 output2ndhdmicode=nec:0x12 outputhdmiquadcode=2nec:0x18 outputi2caddress=3 outputi2cquadchannel=9 input0name=Controller output0code=nec:0x17 output0hdmiswitchpin=36 output0i2cchannel=1 output0audioi2cbit=0 input1name=70cms Ryde input1prioritylevel=1 input1activegpiopin=32 output1code=2nec:0x17 output1hdmiswitchpin=37 output1i2cchannel=2 output1audioi2cbit=1 input1announcemediatype=jpg input1announcemediafile=/home/pi/tmp/input1.jpg input1announcemediaduration=3 input2name=23cms Ryde input2prioritylevel=2 input2activegpiopin=35 output2code=2nec:0x12 output2hdmiswitchpin=38 output2i2cchannel=3 output2audioi2cbit=2 input2announcemediatype=jpg input2announcemediafile=/home/pi/tmp/input2.jpg input2announcemediaduration=3 input3name=Stream rxr input3prioritylevel=3 input3activegpiopin=18 output3code=2nec:0x59 output3hdmiswitchpin=33 output3i2cchannel=4 output3audioi2cbit=3 input3announcemediatype=jpg input3announcemediafile=/home/pi/tmp/input3.jpg input3announcemediaduration=3 input4name=Analogue Rxr input4prioritylevel=7 input4activegpiopin=22 output4code=2nec:0x08 output4hdmiswitchpin=31 output4i2cchannel=5 output4audioi2cbit=4 input4announcemediatype=jpg input4announcemediafile=/home/pi/tmp/input4.jpg input4announcemediaduration=3 input5name=Spare 1 input5prioritylevel=7 input5activegpiopin=16 output5code=nec:0x59 output5hdmiswitchpin=29 output5i2cchannel=6 output5audioi2cbit=5 input5announcemediatype=jpg input5announcemediafile=/home/pi/tmp/input5.jpg input5announcemediaduration=10 input6name=Spare 2 input6prioritylevel=8 input6activegpiopin=19 output6code=nec:0x08 output6hdmiswitchpin=23 output6i2cchannel=7 output6audioi2cbit=6 input6announcemediatype=jpg input6announcemediafile=/home/pi/tmp/input6.jpg input6announcemediaduration=3
If it is desired to have the quad available as a source in the carousel, then the availableinputs= could be increased from 6 to 7, and the following code added to make the quad a source that is then selectable in the carousel:
input7name=Quad input7prioritylevel=8 input7activegpiopin=21 output7code=2nec:0x18 output7hdmiswitchpin=24 output7i2cchannel=8 output7audioi2cbit=7 input7announcemediatype=jpg input7announcemediafile=/home/pi/tmp/input7.jpg input7announcemediaduration=3
