Repeater Controller SSH Commands
In normal operation, the repeater controller is set to start itself on boot-up. There is aan SSH Console menu for basic configuration; some of the more advanced commands are also listed on this page.
Changing Basic Settings
You can change most of the basic settings with the Controller Menu. Just type
menu
The additional commands that can be used from the SSH command line need to you to be working from the home directory. You can ensure this by typing
cd /home/pi
Stopping the Controller
The controller can be stopped by entering
stop
at the command line. This tells all the repeater processes to stop and should show a "Controller Software Not Running" caption on the HDMI output.
Editing the Configuration File
You can also hand-edit the configuration file with the command
nano atv-rptr/config/repeater_config.txt
Use the arrow keys to move about (not the mouse) and save by pressing ctrl-x, y and then enter. Discard changes by simply pressing ctrl-x and then n.
If it has all gone wrong, you can start again with a factory-fresh configuration file using the command
cp atv-rptr/config/repeater_config.txt atv-rptr/config/repeater_config.txt.factory
Note that you will lose all if your previous edits.
Restarting the Controller for Testing
You can restart the controller for testing by entering
rptr
You will see a running commentary of what the repeater is doing in the console window. However, if you close the window, the repeater will stop. You can also stop it and get back to the command prompt by pressing ctrl-c.
You can start the repeater so that it runs and keeps a log of what it is doing (even if you close the controller window) by entering this command:
nohup atv-rptr/utils/run_rptr_nohup_with_log.sh &
Then press ctrl-c to get back to the command prompt.
If you see behaviour that you want to investigate, enter
stop
to force the last bit of the log to be written to the file, and then enter
tail -25 log.txt
to see the last 25 lines of the log.
Do not run the repeater for normal use using these test modes. The log file will grow over time and eventually fill the SD Card, causing the repeater to fail.
Getting Back to Normal Use
At the end of a maintenance session, you should always reboot the repeater to check that it is working properly and put it in its normal mode. Do this by typing
sudo reboot now
Close the SSH window, watch the repeater output and if all is well, walk away.
Advanced Commands
If you need to edit the C code, you can recompile it and run the repeater software with the command
urptr
This will also show you any errors if the compilation fails.
If you need to troubleshoot the output display settings, use
tvservice -s
