WinterHill Receiver Project
Revision as of 16:38, 27 April 2022 by G4EWJ (talk | contribs) (→‎Features)
WinterHill
Features
• There are some restrictions when displaying the 4 TS on an RPi. A maximum of two H.265 signals may be displayed at the same time
• It is recommended to use a PC to display the 4 TS, where there are no such restrictions. See the whpcviewer program below
Timeline
Version 0.1
Version 0.2
Version 1
Documentation
Raspberry Pi Software
  • Install software and reboot
PC Software
Problems
HDTV Monitors
VLC PC Firewall
If VLC does not display anything, even though the VLC title bar contains the correct information, it may be a firewall problem. Check the firewall settings for multiple entries for VLC and make sure that PRIVATE is ticked for all of them. PUBLIC may need to be ticked if you are using multicast IP addresses (starting 224-239).
VLC Initial Screen
To fix this:
Stop whpcviewer
Start a separate VLC window
Close the VLC window
Re-start whpcviewer
