G4WIM PA controller
Revision as of 22:01, 27 April 2022 by M0JUR (talk | contribs) (It's ARDUINO Nano, not Atmel Nano. Moreover, since the compiler flags indicate the Nano firmware is built for ATmega328P as well make it clear that version 3 of the Nano is required - older versions used an ATmega168)
Configurations
The resulting system can be configured in three ways:
  • Full remote control of the PA and shack monitoring of vital signs – using radio link.
  • When PA is in the shack, local control and monitoring - no radio link.
  • Remote control of PA by means of DC down the coax – no radio link or remote monitoring
Monitoring
  • Vdd, 100mV resolution
  • Idd, 100mA resolution
  • PA temperature, 0.3C resolution
  • Bias voltage, 10mV resolution for LDMOS
  • RF power (forward or reverse but not both – depends on HW implementation)
  • Fan status on or off
  • Standby status on or off
Amplifier choices
The design was initially conceived for a Pyro Jo PA which needs 24V DC bias to activate it, subsequently it was modified to provide a temperature compensated bias for LDMOS FET’s. Basically for the LDMOS FET use the temp compensated bias circuit and for the Pyro JO PA use the 24V DC device – one or the other NOT both.
See CQ-TV article and schematics for more detail.
Documentation
Bill of material
File:G4WIM PA CONTROLLER V2-0 BOM.xlsx
Schematics
Microcontroller Firmware
Source code + pre-built firmware files (in respective subdirectories): File:BATC_PA_Controller_Firmware_V2.zip
The controller logic is driven by a standalone ATmega328P, whereas the the radio link uses an nRF905 + Arduino Nano v3. The Arduino Nano code is based on this solution http://blog.zakkemble.net/nrf905-avrarduino-librarydriver/comment-page-1/
IMPORTANT - after building several of these links it became apparent that the timings required for the nRF905 are not the same for all modules. To fix this issue I've created a new improved version of Zak's C code for the Nano v3. The code for the standalone ATmega328P has also been changed to match. Using Zak Kemble's code in the Arduino environment might work - but it is better to use his C code version with my modifications as documented and provided in the above source code link.
When programming the hex files make sure the fuse /8 is unchecked and that fuse for external 8MHz xtal is selected as the clock source. If building your own code from source using Atmel Studio V7.0 set optimisation to -OS (optimise for size).
Any chips supplied by the BATC shop will have the correct code installed for both the ATmega and the Nano v3 - you cannot mix and match Arduino code with the ATmega C code.
