WinterHill Receiver Project
WinterHill
Features
• There are some restrictions when displaying the 4 TS on an RPi. A maximum of two H.265 signals may be displayed at the same time. It is recommended to use a PC to display the 4 TS, where there are no such restrictions. See the whpcviewer program in PC Software below.
Timeline
Version 0.1
Version 0.2
Version 1
Documentation
The current (April 2022) recommended operating system image to download is Raspberry Pi OS (Legacy) with desktop
https://www.raspberrypi.com/software/operating-systems/#raspberry-pi-os-legacy
Raspberry Pi4 SD Card Building and Software Installation Manual (contains RPi4 software download details):
Media:WinterHill-RPi-Installation-Manual-3v20a-Rev1.pdf
Operations Manual - covers the Raspberry Pi and PC Control and Viewing utilities:
Media:WinterHill-Operations-Manual-3v20a-Rev4.pdf
Raspberry Pi Software
  • Install software and reboot
PC Software
Problems
HDTV Monitors
VLC PC Firewall
If VLC does not display anything, even though the VLC title bar contains the correct information, it may be a firewall problem. Check the firewall settings for multiple entries for VLC and make sure that PRIVATE is ticked for all of them. PUBLIC may need to be ticked if you are using multicast IP addresses (starting 224-239).
VLC Initial Screen
To fix this:
Stop whpcviewer
Start a separate VLC window
Close the VLC window
Re-start whpcviewer
