Setting up the WiFi
Jump to navigation
Jump to search
You can set up the WiFi on the Portsdown transmitter from the System Setup Menu.
Option 5 allows you to enter a network SSID and password to connect to a network.
Option 6 allows you to disable the WiFi to stop it interfering with local receivers.
If you want to add a second SSID and password, you will need to edit the file /etc/wpa_supplicant/wpa_supplicant.conf and add the following:
network={
ssid="Home"
psk="Home Password"
network={
ssid="Portable"
psk="Portable Password"
