Copies of CQ-TV more than 2 years old are free to download at the links below and at https://batc.org.uk/cq-tv/cq-tv-archive/
Issue 287 Spring 2025
| Article
Page
| The BATC Needs You
5
| Muntjac SDR – an Update
8
| A learning curve with a 70cms pallet
12
| BATC at HAM RADIO 2025 Friedrichshafen
13
| The Portsdown Newsletter
14
| Q1-2025 Dx news from the GB3JV TV Repeater
14
| Bias-Tee: complicated?
16
| Aerial experiments for DATV
19
| A Portable DATV System
21
| 8th March 2025 Activity day
23
| PE43703 Attenuator Controller
25
| Building a(nother) rotator for /P usage
28
| High power PSU with current limiting
30
| Fun and games with an Arduino
31
| Product review: Banggood Buck-Boost 120W Power supply
32
| Turning Back the Pages
33
Issue 286 Winter 2024
| Article
Page
| Trevor Lumb home built camera
7
8
| Another solution for effective talkback
10
| BATC at the Midland Microwave Round Table
11
| BATC at the RSGB Convention
12
| SRT - How to get started
14
| Antenna polarization: why horizontal?
16
| DATV linear transponder on HB9TV-1 relay
19
| Conversion of 70cms 350 watt power amplifier pallet
20
| AllStar DATV Talkback
21
| BATC Subscriptions
21
| Digital signal path upgrade of GB3EY
22
| November Activity Weekend and a 71MHz bandpass filter
26
| 5-petal ‘cloverleaf’ antenna for 435MHz
27
| A QRO filter for 70cms
28
| JOTA 2024 - from Gilwell Park GB2GP
28
29
| CAT25 - Save the date!
31
Issue 285 Autumn 2024
| Article
Page
| Jamboree on the Air - 2024
6
| Adding a RTC (real time clock) to a Portsdown 4
7
| BATC at the Telford Rally
8
| Conversion of old pallet amplifier to 13cm
9
| A look back at BATC history and the work of Mike Cox
10
| PicoTuneWH - Ethernet software for the BATC PicoTuner
11
| Muntjac - a Pluto alternative for QO-100 DATV
12
16
| My DATV transmitter
17
| Mr Whippy moves on…
19
| CAT 24 – a report of Part one
20
| Presentation of awards at CAT 24
23
| Antenna element holders made by a 3D printer
24
| Adalm Pluto PTT Control
26
| YASS – Yet another signal source
27
28
| CAT24 Part II
31
| Article
Page
| Agenda for the BATC general meeting
5
6
| CQ-TV back issues
7
| ATEM Update v9.5
9
| The LimeNET Micro 2.0 developer edition
10
| A brief adventure with /MM DATV
11
| The BATC gets shipshape to help celebrate RNLI 200
12
| Portsdown 5: under development
14
| What force to tighten a SMA connector?
15
| Fitting my PA in a case with a fan
16
| QO100 from VO1 Newfoundland
17
| A method for remote off-air status monitoring for DATV repeaters
20
| Mr Whippy serves up another seven-band Sundae
23
| My Portable Set-up – Dave, G8GKQ
25
| Modification of Nokia type PA
27
| Out and about for a contest…
28
29
| Article
Page
| HamTV update
6
| The BATC general meeting 2024
7
| Financial report
8
| Introducing the PicoTuner
10
| A new PCB for the PicoTuner
11
| BATC shop EU warehouse
12
| Surface mount Pico adaptor for the MiniTiouner V2 PCB
12
| Going digital with two triple Ryde receivers
13
| Cheap video cameras with poor colour reproduction
16
17
| Impact of Amp Over-drive on DATV?
19
| Portable DATV at GX3WIM/P
20
| Poor man’s bandviewer
21
| The Portsdown noise meter
22
| Modifications to the Polycom VTC Table Microphone
24
| 32dB RF attenuator – an alternative solution
26
| A quick transition for 3.4GHz, or ‘microwaves in a mustard (O.K, coffee) tin’
27
29
| Article
Page
| Out and about in 2023 with the BATC
6
| CAT 24 - Initial plans
8
| David Mann - G8ADM, President of the BATC
9
| The future of the 23cms band – December 2023
10
11
| New SSTV relay in Chatteris, Cambs
12
| Serit FTS-4334 NIM / tuner - good news at last
13
| Switched attenuator for QO-100 transmission
14
| Evaluation of the quality of transmitted and received analogue video signals
15
| Mid-Cornwall beacon and repeater group goes green
19
| BATC represented at “The Day of The Radio Amateur” in the Netherlands
20
| A multiband multimode transceiver
22
| Amateur television at the Spennymoor radio rally
25
| Raspberry Pi 5 - First impressions
26
| Jamboree on the Air 2023 - a tale of two stations
27
| Using an external clock with the Pluto Rev C/D
30
31
32
| Article
Page
| IC-905 - Icom’s microwave and ATV transceiver
8
| You can never have enough computer monitors
11
| An alternative method of generating FM TV at 5.6GHz
12
| A New Hybrid Television Transmission Systems
14
| Out and About…
19
| Small Dishes
20
| How to point an antenna if you are out portable?
21
| CAT 23 – a grand day out
22
| News from Japan 358 km, 5.7GHz, DATV Success
24
| Modbus controlling of PAs with Arduino boards
25
| IARU Region 1 ATV contest 2023 results
29
| The Charon, a HF up-converter for the Adalm Pluto
31
32
