DATV repeater DTMF commands
The BATC repeater controller uses an onboard DTMF detector which detects DTMF from the mic input on a USB audio dongle (using a standard Portsdown white USB dongle). This can be fed from the main input audion, 144.750 rxr or a separate control rxr.
The DTMF decoder enables off-air control of some repeater functions.
DTMF commands
The command sequence is in the format *xx# but the length of the sequence is variable so a command could be *123456# if required.
Configuration file
The actual DTMF command for each function is entirely flexible and is set in the config file.
It is recommended that some command sequences such as shut down are not publicly available.
See this page for a typical config file listing where the DTMF commands have been grouped as keeper commands - Repeater Controller configuration.
Functions controlled by DTMF
The repeater functions which can be commanded by DTMF are set in the controller software and listed below - these cannot be changed.
Suggested keeper functions
dtmfkeepertxoff
dtmfkeepertxon
dtmfkeeperreboot
dtmftalkbackaudioenable
dtmftalkbackaudiodisable
dtmfreset
dtmfstatusview
dtmfquadview
dtmfselectinput0
dtmfselectinput1
dtmfselectinput2
dtmfselectinput3
dtmfselectinput4
dtmfselectinput5
dtmfselectinput6
dtmfselectinput7
dtmfoutputs=1
dtmfgpioout1pin=15
dtmfgpioout1label=shack_light
dtmfgpioout1on=31
dtmfgpioout1off=41
dtmfinputs=1
dtmfgpioin1pin=8
dtmfgpioin1label=cabinet_door
i2cioaddress=0
i2cdtmfoutputs=1
i2cdtmfgpioout1pin=a0
i2cdtmfgpioout1on=51
i2cdtmfgpioout1off=61
i2cdtmfinputs=1
i2cdtmfgpioin1pin=b0
