VK2CRJ Multiviewer
VK2CRJ's script for a Multiviewer (published in CQ-TV 277) does not work if copied and pasted from the CQ-TV pdf, as some of the characters were inadvertently changed in the magazine composition process. Here is the original script.
:: This script requires ffplay to be installed and it's path set
@ECHO off
ECHO Windows multiview player using ffplay by Gary VK2CRJ, 01/09/22
SETLOCAL EnableDelayedExpansion
::::::::::: User settings :::::::::::::::::::::::::
SET "server=rtmp://rtmp.batc.org.uk/live/"
SET /A y0 =  0        &:: Top of player region
SET /A x0 =  600      &:: Left of player region
SET /A y1 =  1080     &:: Bottom of player region
SET /A x1 =  1920     &:: Right of player region
SET /A numx = 4       &:: Number of windows per row
SET /A xw = (x1 - x0) / numx          &:: Player video window width
SET /A yw = xw * 9 / 16               &:: Player video window height
SET /A yb = 30                        &:: Player banner height
SET "flags=-volume 0 -loglevel error" &:: Volume 9 down, 0 up, m toggle mute
:: List of stream callsigns. The ^ is the line continuation character and just for convenience.
:: These will display in raster scan order
SET list=vk3ce vk3rtv1 vk3rtv2 vk2rts^
         gb3tz gb3ut gb3jv gb3vl^
         w6cxatv w6sva f5zbc db0kk
WHERE /Q "ffplay" &:: Check ffplay exists
IF %ERRORLEVEL% NEQ 0 (
    ECHO Error: ffplay not found, please check the path
    PAUSE
    EXIT /B
ECHO Please wait a few seconds for the streams to start decoding
SET /A i = 0
FOR %%a IN (%list%) DO (
    SET /A xdiv = i / numx
    SET /A xmod = i %% numx
    SET /A xpos = xmod * xw + x0
    SET /A ypos = xdiv * yw + yb * "(xdiv + 1)" + y0
    SET /A bot  = ypos + yw
    SET url=%server%%%a
    IF !bot! LEQ %y1% (
        START /B ffplay -top !ypos! -left !xpos! -y %yw% -x %xw% %flags% -window_title %%a !url!
    SET /A i += 1
PAUSE
