PicoTuner
Once proven it is envisaged that PicoTuner will replace the MiniTiouner Mk2 PCB for all new builds, however limited stock of the MiniTiouner PCB and FTDI module will be held in the BATC shop for those who wish to continue to use the MiniTiouner software which is NOT compatible with PicoTuner.
OpenTuner
Portsdown
Version 202403110 onwards of the Portsdown 4 receiver is compatible with PicoTuner but can only display one channel.
See the following pages on using the Portsdown receiver.
https://wiki.batc.org.uk/Portsdown_4#Portsdown_4_receive_capabilities:
https://wiki.batc.org.uk/DVB-S/S2_Reception
Ryde
Version 202403220 onwards of the Ryde Receiver is compatible with PicoTuner but can only display one channel.
PicoTuner hardware
Mike G0MJW has designed a PCB which will host the Serit NIM and Pico board. The Pico can either be a standard board or the WizNet-5100-EVB-Pico which is basically a Pico with an integrated ethernet interface.
Full details are available here: Surface mount PicoTuner adaptor for the MiniTiouner V2 PCB
Programming the Pico
