The Portsdown Digital Multimeter display and logger works with a modified Parkside PDM300 C3 multimeter (seasonally available for £11.99 from Lidl) to display and log the meter readings.
Initial proof-of-concept functionality is limited to a large display of the voltage reading. Based on user feedback, further features will be added.
Modification of the DMM
