To build the unit you only need to buy the following components from the BATC shop [1].
- The ready programmed USB interface.
- The version 2 main PCB.
- The Serit 4334 tuner or NIM covering 143 - 2450 MHz.
- The unit uses an adjustable MCP1826 as the 1V regulator, which can be hard to find.
Mike, G0MJW, has written an excellent guide on building and testing the board - download them here Notes on building the BATC v2 Minitiouner. This pdf includes a Panel layout for the Hammond Box.
Parts list and schematic
Setting up the hardware
Once you are satisfied the voltage levels are correct and there is no smoke, you need to connect your hardware up to a Raspberry Pi4 Ryde receiver or a PC running the MiniTioune software.
Full details including how to set up the MiniTiouner software, drivers and decoders is on the MiniTioune software page.
On the air
Serit LNB DC supply problems
A number of people on the BATC forum have reported their Serit tuners are no longer outputting the LNB voltage from one of the F sockets. The cause is inevitably an open circuit inductor (L101 or L102) after the output has been accidentally short-circuited.
This wiki page has more details of how to repair a broken tuner and details of an add on PCB with a DC current limited supply.
Dual channel output for the Minitiouner hardware
It has always been known that the Serit NIM used in MiniTiounerhas a dual tuner capability and is capable of tuning to and outputting two separate channels. When the version 2 MiniTiouner PCB was designed by Mike G0MJW and Jean-Pierre F6DZP they included a 2nd transport stream output on a separate socket next door to the tuner module.
Because when the unit is used for terrestrial contacts there is no need for a 2nd channel, the USB interface board needed to use the 2nd channel was never developed. However, with the launch of Oscar100, there are often 2 or more separate signals on the wideband transponder. As a result of this potential application, Mike G0MJW has now developed a small daughter board that hosts a 2nd USB module and 74HC-10 chip and plugs into the main MiniTiouner board providing a second USB output whilst still fitting inside the standard Hammond case.
The new daughter board sits on top of a standard header fitted to the empty socket next door to the Serit NIM.
Two new holes need to be drilled in the front panel, one for USB and one for support. A simple bracket needs to be fabricated to manage the USB plugging forces.
Tom ZS6RTG is currently developing a dual-channel version of opentuner.
