Revision as of 17:22, 7 January 2017 by G8GTZ (talk | contribs)
This page is designed to give an brief overview of the Portsdown transmitter project - for more details see the user guide.
There's also a "where do I begin" guide:
For interactive discussion with other constructors see the BATC members forum:
The Portsdown DATV transmitter project provides an easy way to “get on air” with Digital ATV at a relatively low cost, covers most of the common modes and involves some basic construction.
• Symbol rates to include the Reduced Bandwidth (RB-TV) modes and “normal” DATV modes
System overview
Touch screen control
Modulator and Filter board
Audio and video inputs
Where do I begin?
Now you've read the system overview, take a look at the user guide - it contains a lot more information on the hardware required and loading the software and includes a "where do I begin" section..
